Master Cylinder
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
86 720
Car: 1986 720 4cyl Standard Cab
Looks like my MC has a slow leak, that has been going on from before I bought it. The body paint below the MC and booster is coming off like dead skin.
How hard is it to replace?
PEZi
never personally done one.. but from what i've heard its not the worst thing in the world
hopefully it'll go smooth for ya
alientravler
Car: 1982 Datsun 720 4x4
Not hard at all....just remember to use a line wrench for the brake lines end fittings going into the mastercylinder and PLEASE remember to bench bleed the master before putting it on.It will make things alot easier!!...J.T.
pejsa s-13
Car: 91 HardBody, 85 720
alientravler wrote:Not hard at all....just remember to use a line wrench for the brake lines end fittings going into the mastercylinder and PLEASE remember to bench bleed the master before putting it on.It will make things alot easier!!...J.T.
TRUTH +1
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
Its easy. But make sure the rubber seals are installed correctly if you did not get a plunger kit. Don't forget to bench bleed.
moredunes720
Car: 1985 nissan 720 4x4
also be sure and check if your 720 has a clutch damper if it is the clutch master cylinder you are replacing, bleed it first. But it sounds like you are talking about the brakes.
Return to “Datsun 720”
