Master Cylinder
BuudWeizErr
Car: 89 240SXBrakes: 90-92 (IIRC) Z32TT 30mm Calipers
Which Z32 Master Cylinder do I need? Year? TT/NA?
This is the last piece I need for my conversion.
TIA.
SmithSR
Car: 240sx
As far as I can tell, all Z32TT front calipers are the same from production dates 7/'89 - 7/'92. This would mean that both TT M/C's available through that year range will work....because the two different M/C use the same caliper for the years in question. Two of the M/C's interchange between TT and N/A...
The years for the TT M/C are split this way:
from 7/'89-1/'91 P/N N3000-52473
and from 1/'91-all is P/N N3000-52482
The years for the N/A M/C are:
From 2/'89-6/'90 is P/N N3000-52472
From 7/'90-1/'91 is P/N N3000-52473
From 2/'91-all is P/N N3000-52482
These Part Numbers are for the Tokico brand M/C.
tinted
Car: Computers
I don't think it matters, but I have no exp.
Read this: http://importnut.net/300zxbrakeswap.htm#MC
SingleCamSam
Get the 1-1/16" MC
BuudWeizErr
What I'm talking about is what SingleCamSam is talking about. Supposedly, there are 3 different size master cylinders, and supposedly, you need the 1/16" version.
What I want to know is what year that master cylinder came with. It really has nothing to do with the calipers, it has more to do with the brake lines than anything.
tinted
Car: Computers
does this help you any
"The 300 zx 1 1/16" MC is spec'd on something like 7 models, including the early na cars. The key is that it is made by NABCO, not Tokico. About $215 new from Nissan. The fittings bolt right up. Sorry you had to find out the hard way. Also, the NABCO is stamped 1 1/16 right on the MC very plainly."
tinted
Car: Computers
46010-00004 07/1989 to 01/1991 Turbo, 07/1990 to 01/1991 Non-Turbo
SmithSR
Car: 240sx
A way to be sure would be to run to the local parts house, ask for a '92 TT M/C open the box and see if it's cast with 1-1/16". This shouldn't be a problem for a parts house to open the box just to make sure that you're getting what you're looking for.
Tinted, I read that link too....
"I have discovered that Nissan used a 15/16", 1" as well as 1 1/16" master cylinder in 300ZX. There doesn't seem to be a method to the madness, so make sure you know which one you are buying. I used the 1 1/16" MC for my swap"
tinted
Car: Computers
hmm this is getting more confusing as I go.
from d240t2 (unstable hybrid guy)
"As far as MCs go...this is a bit tricky. There are 5 different MCs on Z32s. There are 2 different size Tokico MCs (1" and 17/16"), and 3 different Nabco models (15/16", 1", and 17/16"). With minor modifications, they'll bolt up to S13s and S14s without ABS. ABS S13s, these bolt right on. Non-ABS S13s, if you just want to go to the 15/16" MC (stock is 7/8"), then you can get an 86 S12 200SX MC from autozone, rebuilt, that will bolt right on."
tinted
Car: Computers
some more gibble garble
"Z32 Master Cylinder bore size:84-1/89NA & Turbo = 15/16"2/89-8/91NA & 6/89-1/91 Turbo = 1 1/16"7/90-1/91 = 1 1/16"9/91-96NA & 2/91-96 Turbo = 1"
I got that from some Z website. I'm not sure about the 84-89 MC sizes. All other are correct, as I have purchase ALL OF THEM. The 17/16 is same as 1 1/16 and has all 3 holes for mounting (insert included). The 1" one has a weird 5 sided plug which can be remove and use (no insert though, you have to provide your own). IMO, the 1" works best, it all depends how you like your brake pedal feel.
One last thing, 15/16, 17/16 or 1 1/16 is all stamped on to the side of the MC. The 1" isn't, if this helps any."
tinted
Car: Computers
I did some more reading on Fresh Alloy, and it seems that the 17/16 is pretty stiff. One person suggested the 1" because its a little softer.
tinted
Car: Computers
SingleCamSam
Damn that's some good info Tinted. Somebody should sticky this so it doesn't get lost in the heap. :)
BuudWeizErr
Man, I have to destroy my old master cylinder. Anyone know of any place I can get those things from?
tinted
Car: Computers
SingleCamSam wrote:Damn that's some good info Tinted. Somebody should sticky this so it doesn't get lost in the heap. :)
thanksbut too bad it took a 10 minute search at fresh alloy :rolleyes
tinted
Car: Computers
BuudWeizErr wrote:Man, I have to destroy my old master cylinder. Anyone know of any place I can get those things from?
What do you have to do?
SmithSR
Car: 240sx
The first link you posted. In it details the process of cutting the old M/C to pull the fittings from the casting.
Exar-Kun
Car: 2005 350Z
once this thread is done, I'll try and compile the info into a sticky....:p-chet
tinted
Car: Computers
SmithSR wrote:The first link you posted. In it details the process of cutting the old M/C to pull the fittings from the casting.
I didn't read that far :D
tinted
Car: Computers
Exar-Kun wrote:once this thread is done, I'll try and compile the info into a sticky....:p-chet
cool :thumbup
BuudWeizErr
Exar, Smith, Tinted....
Here are some pics of the M/C I bought today. It's for a Z32, pre-2/91. He said it has a 1 1/16" plunger, but it's not in the casting.
Anyway, tell me if this looks good, and also, do I still need to destroy my old master cylinder?
tia.
BuudWeizErr
Oh, and all three of the holes that have that green thing covering them right now look the same as in that picture.
SHIEF
Ok so if I have a 89 Coupe w/o ABS, then the 17/16 (1" 1/16), MC will bolt right up then, and that's the one I want right? Thanks
BuudWeizErr
SHIEF wrote:Ok so if I have a 89 Coupe w/o ABS, then the 17/16 (1" 1/16), MC will bolt right up then, and that's the one I want right? Thanks
Yup, works like a DREAM.
UncleBen
Car: '05 Infiniti G35 Sedan Sport
'98 Nissan 240SX LE A/T
'95 Nissan 240SX SE A/T
What about a '95 w/o abs w/ the '90-'92 TT calipers?
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
95silviase wrote:What about a '95 w/o abs w/ the '90-'92 TT calipers?
/\/\ what he said!:D /\/\ ??????
-Dan
UncleBen
No one likes us Dan. We are morons
lessthanjakejohn
lol
just second I'll call my friend(tinted) and ask him where he got his info
Dano
95silviase wrote:No one likes us Dan. We are morons
:( lol:pface -Dan
