MAster Cylinder
spankme234
Car: 1991 q45
Well my brake light has been coming on and off this past week. I noticed the brake fluid level was also low. I thought that my brake lines might be shot but upon inspection i found the master cylinder to be leaking everywhere! Not good! Im still in debt from getting my whole front driver side suspension fixed. I looked on line for prices and found that a new one is around 200. but i also saw that a repair kit runs $60. Does anyone know if the repair kit is simple enough that a regular mechanic can do it? Also does anyone have a used master cylinder for cheap?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Check the classifieds, im sure someone has one, remember the 9093 and 9496 are differnet.
texasoil
Car: '92 Infiniti Q45A
'94 Infiniti Q45A
'94 Mercedes-Benz SL600
simple rebuild if its not full of corrosion and pits. Lot sof good used ones available at low cost.
greg_atlanta
Car: 2008 G35 Journey Sedan, silver/black (no sunroof), 1992 Q45 (in a past life)
The cheap fix is to keep filling the brake fluid. Mine leaked for 5 years before I replaced it, but only a minor leak in cold weather (had to top it off once a month or so). After replacing it the brakes felt the same as before. You can also tighten the two nuts in the back, that might help.
5seryan
Car: 1995 Q45t R.I.P.
Thats kinda scary. I dont mess around with brakes. The thought of not be able to stop a 4000lb pound Q barreling along gives me the chills.
Q451990
An A1 Cardone reman at Autozone is less than $85... Is it as good as OEM? Not sure - but it's better than leaky OEM. Fenco is $67, but Cardone has a pretty good reputation... Q45Tech (where has he gone anyway?) seems to trust Cardone. They rebuilt the ABS actuator on Q1 five years ago and it's been fine - so I've had a good experience.
The M/S on Q1 was leaking when I bought her... let it go for a while knowing that it was covered under the 100K warranty. Went out of town for a few days and while I was gone it dumped the whole resivoir in the driveway. Dealer sent a flat bed at no charge - but it still goes to show that you never know when an iffy brake part will fail completely.
Heath
