p00t »
https://forums.nicoclub.com/p00t-u5026.html
Sun Nov 09, 2003 11:29 pm
if you had the brake disconnected from the car and lots of fluid came out then air is in the lines. often the air will work its way higher up into other pipes.
just try bleeding out the wheel on the other side of the car, for example if its the right rear caliper you changed bleed the left rear as well.
also make sure you followed nistechs advise properly, when you bleed you must: push pedal down, open bleeder, close bleeder, pull pedal up and repeat. it takes awhile, its a *****, be patient.
good luck.
