Master Cylinder interchange 1990-1993 to 1994
Panther in a Q45a
Car: 1995 Q45, 1994 Q45, 1974 Pantera, 2006 Hummer
Searched and read several articles on the 1990-1993 master cylinders.
Wondering if there is any advantage to using the 1 1/16" bore unit on a 1994?
Next question is if the 1990-1993 master cylinder will work on a 1994?
The reason for asking is that my 1994 MC has a big part built into the line right below the MC.
Anyone know what that part is?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
the 90-93 as you may know uses the tokico MC, which has the 2 fittings on the side. The 94-96 uses the nabco which has one on the side and one on the bottom with that big adapter thing..
You could proably make it work but I dont know what the advantage would be?
Panther in a Q45a
Following your advice from about 3 years ago
zerothread?id=128705
picked up a set of Z32tt calipers and rotors, and four G35 18" wheels.
Read another thread discussing how the early MC are 1/16" larger bore. Is it worth it, or am I chasing my tail for nothing?
elwesso
2007 BMW M Coupe
Ive had Z brakes on my Q for 3 years and Ive never felt compelled to change the MC.
Panther in a Q45a
One less item to change
