If the code was a P0448 then an ECM repro could be necessary in order to make the P-DTC erasable, there's a bulletin about it:
https://static.nhtsa.gov/odi/tsbs/2020/ ... 8-0001.pdf
However, there are a lot of different MAF-related codes and it's hard to help you without knowing what it is. If it was P0101, that's never caused by the MAF itself and is usually from a small vacuum leak, dirty Throttle Body, or bad PCV Valve.
The part number for your MAF is 22680-5RB0A, RockAuto lists a very reputable Hitachi for $120. There's also a Beck-Arnley for $65 but it I don't think I'd trust it. Aftermarket MAF's generally work fine on Nissans, but you
must perform an Idle Air Volume Learn (IAVL) after replacement in order to match the new MAF to the the Throttle Position Sensor (TPS) in the ECM's memory. If you have the CVTz50 app to monitor your transmission then it has work support for IAVL and you can DIY it. The MAF itself is two phillips head screws with a stubby screwdriver to replace, and should take no more than 10 minutes. IAVL will take another 10. Cleaning the Throttle Body (if needed) is about a 30 minute job. Reflashing the ECM (if needed) is also about 30 minutes. So by my calculation they should be charging you about 1.5 hours at most. Dealer rates are generally around $150/hr these days, so assuming they use the most expensive sensor and it needs
all the work, that would make the tab 225 + 358 = $583. That means they're fixing to charge you 2.5~3.0 hours for labor, which is ridiculous.
