Mass Airflow sensor problem??
black94prelude
i have an 89 240sx w/k24e and i need help.evidently the plugs on the wiring harness that go to the mass airflow sensor were completely removed (for some unknown reason)i have another wiring harness but those wires are cut about half way down and i cant tell where they are supposed to go. if anyone could tell me where in the ecu they hook i can direct wire them up and have everything working.thanks, if u could please send a pic of the ecu so i can see where they go.
thanks,chad
NISTECH
You should be able to splice off the original wires in your installed harness and use the connector off the extra harness you have to hook it up. Pics or a more accurate description of your delima will help out a great deal. Attempting to hard wire to the ECM would be a pain in the rear. Splicing off what you already have in your harness is definitly the easier way.
