Budget for it and the O-ring gasket. Probably toast. Not all failures are noisey. Measure fuel pressure as detailed in posts by Q45tech.66mgb wrote:I'm guessing fuel pump is original ('92). No hum from pump though.
Maybe you didnt get the ECU harness seated right? Glad you got the NICO ECU FINALLY ( )...66mgb wrote:You mean my NICO ECU that I just installed on Monday? (wink wink)
Yea, I'll check it out. I'll keep you posted. I'm going to check the connection to the MAF first. I shot the connection w/ CRC this summer, so it should be clean....
New parts frequentlywill highlight old parts that need replacing.66mgb wrote:It's the nature of the beast - install one new part and fix 3 more....
