DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Thu May 14, 2015 8:15 pm
Check the connector for corrosion, and make sure that pushing it back on that you didn't disturb a hose clamp/loosen something accidentally. Also, do you have a cone filter or the OEM box? Re-installing the OEM box can sometimes end up with an intake hose open/vacuum leak...worth a check!
Also, using some MAF cleaner surely can't hurt if you have never had it off before as you said.
