Ramius83 »
https://forums.nicoclub.com/ramius83-u6643.html
Tue Jul 10, 2007 5:16 pm
Yep, Good old P1320 is the Ignition Signal Primary. As NISTECH has stated, it is nearly impossible to pin-point which coilpack it is that is causing it. Your best bet would be to replace all the coil packs and go from there. They can usually be had at a dealership for around $125, that is what they charge at our Parts Department. Good luck.
