Mass air flow sensor (black with white stripe wire where doe,s it )
tony/ka24de
(sr20det)does anyone know where the black with a white stripe wire coming from the mass air flow senser goes to? The other wires on the mass air flow sensor are connected.Want to no where the other go,s too .................................One more thing ,do you guy,s no where the 95 240sx heat wire your temp wire is in the 95 240sx and what color it is so i can connect to the sr20det ecu......................THANKS
ImportIntelligence
Car: Big turbo's :)
The black with a white stripe should be your power for the AFM.
