alexlloyd wrote:. . . how do I know for sure that the CEL is indicating a mass Air FLow sensor. . .
if you're talking about a 95 max, save yourself the trouble. in the link scott posted, there's a pic of your ecu behind that panel under your console. above the ecu on the 95's is an OBD II connector. double check and make sure you have the connector. my max is a 95, production date of 94 and i have the connector. you can go to Advance Auto parts (tell them it's a 96 or they'll tell you they can't read older than 96) show them where the connector is because most are on the driver side (we have an OBD I connector on the driver side). get your codes read, and go from there. out of all the A32's that come in with CEL on, they end up being 1 or more of 3 things: oxygen sensor (various ones), knock sensor (if you look at your motor from driver side, the knock sensor is located just under the intake manifold on the block, kind of a pain to get to), or catalyst effeciency below threshhold (either a rear oxygen sensor or cat. conv. is bad). you should be able to get a print out of the codes from AAP. blah. good luck bro.
