Skibane »
https://forums.nicoclub.com/skibane-u40096.html
Sat Nov 12, 2011 2:00 am
It's become HUGELY popular for use on generators, chain saws and other small engines where the fuel in the tank may sit unused for a few months. A Wes mentioned, the recent addition of ethyl alcohol (ethanol) to pump gas is one of the main culprits.
Basically, the problem is that the ethanol in gasoline attracts moisture, which tends to fall out of suspension over time. This can result in clumps of water in the gas, which can't be burned by the engine.
Some folks use the HEET fuel system de-icers for improving vehicle driveability. Adding more alcohol (in the form of HEET) allows the water to be re-absorbed into the gasoline, where it can be burned as the gas is consumed.
So, even though the presence of alcohol in the gasoline is the cause of the problem, adding even more alcohol can alleviate the problem. Strange, but true.
