HKS FCon VPro also uses a map sensor. I like the FCon because of the diagnostic features, data logging and the 4 32x32 fuel/ignition maps it can store.Rosco wrote:So in the long run I'm thinking screw the MAFS and upgrade to a MAPS...How do you do this and how much would it cost? I've only entertained this thought recently and now I'm looking into doing for a few reasons: 1) More accurate 2) Easier to tuneThat's all I can think of right now. I don't think this topic has been "delved" into too often on our SR engines. Most of us slap a Z32 and an SAFC and call it a day (I'm guilty of that). So Pro's, Con's?
Have you considered using a MAF based Apexi Power FC? What are your power goals? I'm sure the Z32 can support it.Rosco wrote: Most of us slap a Z32 and an SAFC and call it a day (I'm guilty of that). So Pro's, Con's?
HKS controller for what??? If your trying to keep things efficient, keep it simple. Power FC, Z32 MAFS, tune and go.Rosco wrote: I'll take look at the HKS controller.
HKS FCon VPro is even more simple: FCon, tune and go. No MAFS and a 32x32 bit fuel/ignition map. PFC has 20x20 but still more than adequate. Factory ECU has 16x16 map.highmilehatch wrote:
HKS FCon VPro - If you can find a local authorized pro-dealer, go for it.S14SRPilot wrote:
You will need access to an HKS Pro dealer though. I should have mentioned that. If you're in CA you're good to go.
MAP Sensor= Manifold Air Pressure Sensor. A MAP Sensor is a wideband sensor that measures air pressure in the intake manifold.travis newberry wrote:how can you have no way of metering air? you cant guess... and you cant rely on an o2 sensor. so what then? there has to be a way of measuring how much air is being sent into the engine for the correct fuel/spark delivery...
that is what i was talking about, he said no MAF, and didnt say anything about a map, so i thought it didnt have either, which i dont think is possible... i didnt know the fcon came with a map...S14SRPilot wrote:HKS FCon VPro is even more simple: FCon, tune and go. No MAF
