MAP or MAF on a 1994 Infinity
efrylink
Car: 1994 Infinity Q45
Does a 1994 Q45 have the MAP or MAF Sensors and if so where are they located. Trying to add a tuning module. Thanks in advance
Q45tech
We always suggest new members download and spend a week studying the Factory Service Manual where 95% of simple questions are answered.
Single MAF with 4.4 volts peak out of 5.0 volts.............a faking of voltage doesn't do much as the timing changes with voltage along with injection time.
With a lot of experimentation you can find 20 HP and torque by increasing MAF voltage ~~3-4-5%. This reserve is there because of the possibility of operating WOT at even 20F ambient. [5% more density than 77F].
pm_page6776
Car: 2009 A/C 2.5S
Hey Q45, I am also from marietta. You don't happen to work at Nalley do you?
goody90q45
Car: 1992 Infiniti Q45 (sold)
efrylink wrote:Does a 1994 Q45 have the MAP or MAF Sensors and if so where are they located.....
The Mass Air Flow Sensor is attached to the outlet of the air (filter) box. It's round, 90mm diameter and has a 2" square box attached to it. Let us know how the module works.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
pm_page6776 wrote:Hey Q45, I am also from marietta. You don't happen to work at Nalley do you?
Q45tech is loosely associated with T-3, primarliy the one in Smyrna on Cobb Rd., I believe.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
efrylink wrote: Trying to add a tuning module.
Pleae explain what a "tuning module" is. Rather scary you are trying to modify a component you can't identify.
If it one of those resistors for the MAF, save yourself some time and your engine some grief. Don't do it.
But do check the spelling on your trunk.
