IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Mon Oct 04, 2004 7:45 am
honestly, i like maf systems better because they adapt to change better, and its a direct measurement of airflow instead of calculating airflow based on pressure, known VE, and temperature.
a map system is good, but changes that affect the motors VE require retuning.
if you have made all the major changes that you want to make, and tune the map system properly, it will be fine.
the maf vs map debate really gets going when your dealing with stock cars that you want to modify. in that case, a maf system will be more adaptable because the maf is measuring the increased airflow.
if your car is already modified to an extent that your happy with, and dont want a maf sensor restricting airflow, then convert to map.
if you not done modding the motor, stick with the maf until you are close to done. otherwise, that shiny new intake is gonna be a few hours on the dyno.
its a tradeoff, like everything else.
map sensor is not as fragile as a maf sensor, but the maf is more accurate due to it being a direct reading. maf easily adapts to change, but a map system needs tuning with changes to VE.
