MAP button replacement ?
Forum for the unique Murano, and official home of Nissan Murano Club!
Twoputtpar
Car: 15 Nissan Murano Platinum
Noticed a void where a button used to be , as far as I can tell it used to say MAP , its located to the opposite side ( right ) of the CD eject button on a 15 Murano Platinum.
Anyone happen know where I can order one, or what it is called exactly ?
Thanks
Also, what is this button used for ? The one with the seat picture on it ?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
That slot has the map SD Card in it, what goes over it is just a rubber cover. I don't think they sell the cover separately, so your best bet is probably the junkyard. The switch raises the backs of the rear seats if they've been flattened for cargo. I can't recall if it's an up-down switch and you can also flatten them.
Twoputtpar
thank you sir
VStar650CL
Technical Expert
:dblthumb:
Return to “Murano Forum”
