EDIT: So I now believe that these rogues with HID assemblies have motorized height adjustment, correct? This would explain the motors moving up/down as described below but not my main issue.
First issue was the driver's side turn signal blinked fast...thought it was a bad bulb. Looked at front bulb with lights on, and sure enough one of the two filaments (the one that is always supposed to stay on, not the one that blinks) was out, but didn't look broken....weird. But when I turn on hazards, they blinked fine always.
Then, I turned the hazards on one day (blinked normal speed, both) and the front headlight assemblies (BOTH) started making a loud popping sound and I went out and watched both entire housings literally popping out when blinkers would blink (like popping popcorn). YES, the housings were MOVING (popping) with the blinkers. These headlights have no motors attached to them like BMW's and Merc's etc do for turning and auto level adjustment, so WTF...
Then one night I had my headlights on AUTO mode and they would not turn on at all. I had to manually switch them on which they then would come on.
What the hell is going on here?? All help is greatly appreciated!!
