BaliLover »
https://forums.nicoclub.com/balilover-u6785.html
Thu Oct 07, 2004 6:45 pm
The vaccume line should be running to the larger port coming out of the BOV, the port that is screwed into the purple section, the bottom (port in the silver part) port should be left open. And yes, BOVs that are atmospheric will stall out when you go from boost to idle, thats very common.
What do you mean, turned around, you just turned it on its mount? That shouldn't affect anything with the function of the BOV.
As for the 15psi thing, what boost controller are you running? It may not be setup properly, or you may just be hitting a boost spike at 15psi and then it levels off to where it is set 10psi. HOWEVER, the stock turbo shouldn't be pushed to 15psi, it won't last very long if you do. We've got 3 SR swaps around town and they all seem to have a max constant boost of around 9 or 10 psi so I've come to believe thats about all those older turbos can really handle without being rebuilt.
The engine harness has nothing to do with the power windows, you may just have a bad motor, blown fuse, bad switch, etc. There is nothing in the wiring they would have done that connects to the window.
Not to be an ***, but you took a car that was running what I'd consider to be normal (BOV stall), started messing around under the hood and now the car runs poorly. Thats not anyones fault but your own.
I would suggest checking around for broken vaccume lines, or even disconnected ones. Make sure the vaccume line on the BOV is going to the port on the purple section and that you are recirculating AFTER the MAFS
Are your rear brake lights constantly on, or just the brake light on the dash?
As for the oil leak, double check the valve cover, it wouldn't take much of a leak from it to cover everything, and if you didn't have a new VC gasket installed or the VC pulled for any reason and reinstalled, then that is something I would suggest doing.
Its almost impossible to know if an engine has a slight oil leak as an importer. Most import companies will clean the motor thoroughly so the shop that buys it and installs it has no idea. its not until you get the car on the road and puts some stress on it that the leaks will start to show themselves, and when they do, its usually all at once. Leaks are just a fact of life when it comes to older motors.
