Manual window to power window conversion?
SloS13
My door is banged up real good (power window) and there is a manual window door at the junkyard. Will the innards just swap over?
Thanks,Jess
SloS13
bump
180fan
Car: 89 fastback
Yep
SloS13
Thanks for the reply 180fan :)
DeeZNuTTss
Car: 240sx 4/1991 hatchback s13
i have the manual windows. so if i get the motor ond everything i can make them power. is it hard is it even worth it? thanks
180fan
Car: 89 fastback
Well first thing, get a 9v battery (the type you see for your smoke detector) and then test the motor to make sure it's good. If it makes some grinding noise pass it as they're expensive to replace. I think they run around 200 or so at dealership so they're a pretty costly item. So yeah they'll work fine as long as you grab everything on the inside of the door. The wiring is something else you should have a look at when you're at the donor car. It shouldn't be hard, just a bit of a pain to get the wires through the grommets.
DeeZNuTTss
so it will work as long as i get the motor and slider? what years will work and if i have an after market auto locks will that get in the way. thanks again
180fan
Car: 89 fastback
Dunno about those auto locks. If you're talking about an alarm with door locks, I think those can be done away with and have the solenoids from the stock system used. For the door stuff, basically grab everything on the inside. The install will be much easier that way and shouldn't cost that much more. I'm pretty sure if you've an s13, any of the s13's door innards will work. However, remember to grab any of the extra wires that run the door locking system that lies under the dash as the manual door crank system may not have that part of the harness on it (or you could check for it yourself either way would work)
