manual window regulator replacement 240sx
NismoKnights
Car: 240sx, s13 coupe
Well I have 89 coupe 240sx s13 and my Window's broken and its a manual window I have no clue how to fix it, Pretty much what happen is that i would try to roll up/down my window (manually) and it'll just keep spinning like the gear not even in (or broken) And....Its raining Here...
I've looked up on google *manual window regulator replacement 240sx* and I got nothing..well at least I think, Plz help a fellow Touge Driver out. * plz pic if possbile*
Hijacker
Car: '92 240sx Convertible
'94 F-150
Step 1: Stop saying you're a Touge Driver
Step 2: Look here.
Step 3: Read section on "Door"
Step 4: ???
Step 5: Profit!
In all seriousness though. It's an easy fix. Literally, take your door panel off, remove the 3 bolts holding the window winder in place, 4 nuts holding the regulator in, and probably the bolts holding the glass stoppers. It'll slide right out. And then installation is the exact opposite.
NismoKnights
....O.ok..Thanks for the help anyways. let me guess cops read up the forums and blah blah blah right?
