evildky »
https://forums.nicoclub.com/evildky-u13100.html
Sun Mar 11, 2007 6:14 pm
there are 2 types of manual boost controllers one is a bleed type and a restrictor type, both can allow boost creep the problem real is they are not very accurate and you have to dial them by trial and error, the JWT remapped ships (recomended if your gonna run more boost), use boost jet which is basically a restrictor type but not adjustable, electronic uses a fast acting valve and is very acurate but also very expensive,, the other option is to use a larger wategate actuator factory set to the amount of boost you want to run, or an expernal wastegate with replacable springs to tune the pressure, and again with any of these if you plan to run extra bost you should get a remapped ecu or stand alone to allow for extra fuel and spark retard under the higher boost levels
