Koby »
https://forums.nicoclub.com/koby-u28122.html
Sun Apr 24, 2005 11:57 am
Interesting subject.
Back in the day you used to need to turbo-time your turbocharged engine because conventional (dino) oil will coke up if it isn't cooled down slowly from high temps.
Well, having oil coke up in your turbo's journal/ball bearing is a bad thing and will kill it in no time at all.
But with the advent of fully synthetic oils that do not coke at all, you really have nothing to worry about. In theory you are completely fine to just shut the engine off even after WOT pulls.
But in reality, it doesn't hurt anything to let your turbo have coolant and oil run through it for 30-60 seconds after being under postive manifold pressure to let things cool down better.
Personally, I run fully synthetic oils, and just stay off the throttle for a minute or two before I reach my destination. This is prevention enough
