Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Fri Dec 30, 2005 10:06 pm
Right, but it would make that sound in all gears, plus the KA (at least in the 240, can't speak for altima or hardbody) doesn't use a bearing to speak of, it's more of a copper bushing. I would suggest it is one of the internal shaft bearings, or your fluid may be low. As I am sure you have checked the level, try beating the crap out of it, and see if you can make it happen in another gear (or even the same after some hard driving) this can identify which bearing you may be looking for. Also, when checking level, look for particles. That may help diagnose your issue.
