lwhite49 »
https://forums.nicoclub.com/lwhite49-u18985.html
Sun Aug 15, 2004 6:56 am
My son recently purchased a 93 240sx with a noisy 5-speed transmission. He has just purchased a good used transmission from (I assume) a later model 240sx. After removing the original transmission, we noticed two differences in the transmissions. The transmission that we removed has a vacuum(?) port on top that runs to a bracket that is held on by the top center transmission mounting bolt. It also has an additional switch or sensor located on the front of the transmission to the rear and slightly higher than the reverse lamp switch. The transmission that we want to install has the vacuum port plugged and there is no hole for the additional switch/sensor. Is the additional switch/sensor a fourth position switch and is there anything special that we need to do in order to use this transmission? In every other detail, they appear to be the same. If someone can help me ASAP, then I can get this thing back on the road and get my son back out of my Suburban. Thanks in advance. LWhite49.
