1qckser wrote:Until you get your car running you should not cast doubt on anyone else who has achieved something you cant, talk to the guy, he is very nice although busy and does not have to prove anything to you.
Agreed.
Also, putting a manual on a VH for the purpose of powering a Z32 is a HUGE difference from swapping a manual trans into a Q.
The topic has been beaten to death, but here are some of the preliminary problems you'd have to overcome:
1) ECU - a workable solution is probably within reach, but keep in mind all the issues to be overcome here
2) Trans tunnel / shifter placement: Your shifter would be nowhere near the current autotrans shifter, necessitating an entirely custom console and possibly dash - also surmountable with sufficient $ and know-how. Keep in mind all the sensors and wiring currently in this space will need to be relocated.
3) Clutch pedal - can't see where you'd mount one as the firewall / footwell wasn't designed for a clutch.
4) Clutch M/C - Again, very little room to work with on the firewall.
5) Clutch slave cylinder - Even less room if you find a place for the M/C.
6) Relocation of the E-brake - Major fabrication, see custom console above.
7) Driveshaft - Custom fabricated shaft required - Again, $ is the issue.
8) Cruise control - probably easier to delete completely.
9) Proper gearing - you'd want to make sure whatever trans you decide upon WORKS well with the VH's powerband. Might necessitate a 4.08 or 4.36 gear swap to adjust final drive ratio for optimal performance, and would take you right back to the ECU.
It'd be an awesome project, but likely to become a money pit...
Personally, I'd rather buy a mid-90's Acura Legend Type II with the 6-speed and supercharge it. Less money, a great-looking car, and aside from the wrong-wheel-drive matter, a suitable substitute.
