since the instructions from other threads were incorrect (both hex's are different for drain/fill plug) here goes.
Tools Needed2 dudes (you can do it by yourself but who's going to pass you a beer)funnel and hose (1' long)3 1/2 Quarts of transmission oil10mm hex socket (fill plug)14mm hex socket (drain plug)jack and stands (not needed as there is enough room under car to do it)
Instructionsyou will be able to see both plugs from the LH side behind the wheel right awayloosen fill plug first, cuz if you're drained already yer screwedloosed drain plug and let drainget your funnel and hose set up through engine bay to fill plug (if you get the bottle with the nozzle on them you can do it from below it'll just take awhile)pour your oil in (if car is jacked up you won't get a level fill but if it is lvel and the oil pours out then you got enough)close em up, it says to torque them on the FSM but hand tightened to where the plug was originaly is good enough and the torque is minimal
so behind the drivers front wheel, top circle is fill plug 10mm hex, and bottom circle 14mm
me hard @ work
all the info and more at http://www.nicoclub.com/FSM/Sentra/2002/
