elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Sun Dec 23, 2012 8:38 am
Honestly you're better off using something externally rather than a stop leak that you put in the fluid.. The key will be to get the surface really clean, otherwise nothing will stick..
there's not going to be any magical snake oil you can add to the fluid to stop the leak. Where is the leak coming from? Can you tell? Of course it looks like it's coming from the bottom, but you need to try and source the leak to the highest point.
