marian99 »
https://forums.nicoclub.com/marian99-u267509.html
Fri Aug 26, 2016 3:06 am
hi guys, sorry for my english in case something is written incorrectly, it's not my first language ...
I was wondering if you experienced same as I do with the manual transmission gear box, I have 2WD xTrail
All the cars I had before the stick shift was smooth, changing the gears was smooth with no need for pressure to apply or a need to move from 2nd gear to neutral first and only then to 3rd. I do not want to say that the gearbox is faulty or anything I just noticed two issues
1. When I change from 1st to 2nd and from 2nd to 3rd especially, it does not go that smooth and effortlessly as in my other cars I have driven (Toyota, MB), ie changing from 2nd to 3rd if I move quickly it is noisy and kinda not smooth and easy (not sure how to describe it better) , if I do it slowly leaving it a second in neutral it is better but still not smooth enough for me
2. While driving my stick shift is doing slight movements forward and backward. When I press the accelerator it moves backward a bit (1/2 inch or so) and this is happening on all gears, when I lift my foot off the accelerator pedal while in a gear it moves same way forward. And this is happening on all gears. Also I've noticed that on some gears, 2nd and 3rd, without pressing the accelerator pedal the stick is moving forward and backward itself slightly, I am not even having a hand on the stick, but this does not happen all the time, only sometimes.
Have any of you experience anything similar ? What can be done about this ? Thank you very much for any help and advise. Marian
