Manual Transmission Fluid (MTF) - Tutorial
All things Altima Coupe.
D-Roll
Car: 08 Nissan 350Z Touring Coupe
mcheddadi wrote:yeah, that's about right 1.7liters
Schweet! Thanks
SHIFT_COUPE
Car: 2014 Infiniti Q50 AWD
Tutorial also added to our tech page
http://www.nicoclub.com/articles.php?id=335722
mcheddadi
Car: R8
there seems to be a problem with the smiley on the tutorial page, they are HUGE in firefox lol:
SHIFT_COUPE
Hahah nice. Fixed now
Sith LL_Coupe
Car: Precision Grey Altima Coupe 3.5 SE CVT (Prem. & Tech. Pkg.)
You missed a one right above the lunchbox pic.
Thanks mcheddadi for the awesome tutorial and Shift_Coupe for the quick add to the tutorial page.
mcheddadi
Car: R8
lol! yeah haha, and there's also an image that's not displaying correctly because tyler forgot to complete the [/img] tag lool
slacking off tyler?
SHIFT_COUPE
Classic example of being a few beers deep while doing some evening forum work.
Definitely fixed now
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
the pic of the hex bit socket... on carbon fiber... whats the part? your lady rockin a CF hood?
mcheddadi
Car: R8
nah It's a 350Z's carbon fiber hood. I needed a picture of the hex bit socket, but mine came out blurry, so I used a picture of someone else's hex bit socket on his hood
theoctopussi
Car: 2008 Altima Coupe 2.5 6MT
I thot Royal Purple is better?
mcheddadi
Car: R8
You can try it and tell us, but from personal experience and research on the net, I've found that redline is more suited for our trannies
theoctopussi
I'll try it on the next oil change....
blancs3030
Car: 2008 Altima Coupe 3.5L SE 6MT
I changed to Redline transmission oil today, so far I can't see much of a difference maybe I haven't driven it enough yet. I never had any problems with the conventional oil in it, but I wanted to see if it could be any smoother.
mcheddadi
Car: R8
well you notice it most on problematic transmission, but if your transmission was fine then it just will continue to be fine, albeit a tiny bit more smoother.
Nissan's transmission are mostly hit or miss. You got lucky
If you want a DRASTIC improvement, you should get a better shiftknob + the MTF change
blancs3030
I feel a difference now, I think...lol. I was expecting it to feel smoother pushing the shifter into different gears, but it feels smoother at the clutch I don't know if thats what your feeling, I think the placebo effect might be working on me.
D-Roll
Im going to stick with Amsoil syntheitc 75w-90 transmission oil. I used that in my 02 SpecV transmission
Blackmobile
Car: 2008 Altima Coupe 2.5S Super Black
old thread, but i used the tutorial to change my transmission fluid today and all i can say is WOW, rev matching is so much smoother. i highly recommend switching if anyone else has thought about it but never got around to it. took me 3 years to finally do it after saying I was going to like 2 years ago. i had my 3 year service and they told me my transmission fluid was dirty so i figured it was the perfect chance to do the change. glad i did.
one thing i'm slightly concerned about the change is that as the guide says, mix in 1 full bottle and 700ml of the other but when i drained my fluid, i put the old fluid into my mixing bottle that i used to mix the MTL fluid and there was definitely more than what i put in, more like 2L or more of fluid. should i have used more MTL mix? is it because i replaced the fluid with synthetic that i don't need as much?
RicerX
Car: '20 Titan Pro4X
Can't remember exactly what the owner's manual calls for WRT fluid capacities... I'll need to look it up. I need to do this swap too. Just hit 30k miles and I need to do a full fluid check anyway. I had Redline in my Spec V 6MT before and it was awesome - been meaning to do the same in my Altima.
RicerX
Also - MAD props on use of search. :dblthumb:
star2nv
Car: 08 altima coupe 3.5 mt
update, did you find anything out on the amount discrepancies? i want to do this ,this weekend and was just checking.
Blackmobile
nope, but everything is running super smooth, so i think i'm good to go.
star2nv
ok gonna do mine to then .got the short shifter and shift knob as well.
TTS.Zero
Car: 2008 Nissan Altima Coupe 3.5
Hey, don't mean to kick dead dog... but Redline now has MT-85 transmission fluid. Can I assume that it is safe to use? (noob)
RicerX
TTS.Zero wrote:Hey, don't mean to kick dead dog... but Redline now has MT-85 transmission fluid. Can I assume that it is safe to use? (noob)
Yes sir! Just used it in my Z. Altima 6MT calls for the same - it's a proprietary Nissan lubricant grade for their manuals for the most part.
No worries on the kicking dead dog thing - you used the search and found the correct thread. You're doing it right. Carry on!
Altima6speed
Car: 2009 Nissan Altima 6speed :)
He did this on a 3.5. Is it any different for the 2.5 ? I have a 2009 2.5 sedan 6MT and need to change the transmission fluid and was thinking about using same method and fluid
