Congrats!!!Yup!! PB Blaster, torch, breaker/cheater bar and some elbow grease work most of the time. I forgot to tell you this... Someone said Lucas oil stabilizer makes transmission feel like new. I'll try it next time.MNVERT wrote:i took it to the transmission shop they heat up the bolt and came out like a charm. o and never ever ever use a impact gun on the bolt they say it just make it worst ..
94_240sx wrote:i put some lucas oil stabilizer in but not much im worried that it might damage the synchros casue i dont know if its good for our brass synchros in our transmission.
You can weld a bolt to the drain plug and try to remove it and yes, you can fill it from shifter hole, but you have to pour exact amount of transmission fluid. You want to do it right, so I say weld a bolt on the plug.shift_logic wrote:i know this is an old thread but i really need help. i have a 1990 300zx and i cant get the gear oil plug out of the transmission. is there another way to fill the transmission via the bottom plug or at the shifter? i need help quick cause i have to drive my car. i tried a breaker bar, pb blaster, torch and all i did was round out the square hole in the plug. it looks as if the dumbace who had the car before me put locktight or silicone on the treads. what do i do now?
