Working on dropping the 5 speed manual transmission drop on my 300zx, I took off the support bracket from the assembly, exhaust tubes, however do I need to take off what looks like the heat shield in order to get the control rod off from the shift lever?? I'm trying to get my EGR valve off as it is extremely clogged and I've heard that you can either drop your transmission or remove ur engine.. I dont' have a lift to take my engine out so I'm in the process of dropping my transmission..
