manual transmission adapter plate for auto to manual swap
ZERO_HOUR
I was working on an auto to manual swap and thought I had all of the parts....
It's apparent that the plate between the block and the transmission is different - the auto. has a 1/2 plate that loops around the starter and a small bottom plate, and the manual looks to have a 360 degree plate that wraps around the flywheel.
My question is if i need to have the manual plate in order to do the swap? The 1/2 plate from the auto. lines up fine, but the bottom plate cannot be reused.
Should i just get the right plate? Is it critical to have the manual one?
thanks in advance,
D
nightkid86
Car: 97 S14 SE
I believe unless you want a hole at the bottom of your transmission then yes you need the 5 speed one. Check the stealership
smelly240
Car: 240
lol you can have mine - it pinched my finger today and i hate it.
irocknrol2
Car: 1991 240sx Hatch/1993 240sx Coupe
is it critical? NO, but should you install it? YES. if not the bottom of your flywheel will open to dirt and debris. Just check the local junk yards, you should be able to find one.
kings88
Car: '89 S13 coupe
duct tape?
Ligouri Rd
Car: '96 Nissan 240SX
kings88 wrote:duct tape?
You do not deserve a 240 for saying that.
Yes it is critical, unless you want to get dirt and sheet into your throwout bearing.
nightkid86
Car: 97 S14 SE
Ligouri Rd wrote: into your throwout bearing.
and into your clutch plate and pressure plate
