boxcarbill wrote:Between 0 and 60 probably, but not doin over 70 mph it ain't
Personally, I don't need to go over 70. The highest speed limit on a road in my state is 70. Cruising at 70 for 190 miles, then a day's worth of city driving, netted me my 33.99 MPG tank. I'd imagine that a full tank cruising at 70 might actually net me close to the old CVT EPA rating of 36.
The theory of the CVT's efficiency by being able to run in the 2k RPM range for long periods of time at high speed is offset by the reality that, by design, automatics are less efficient because they are more complicated machinery than manual tranmissions (laws of mechanical efficiency). Combine that with the fact that the CVT is the more complex of the two automatics (Two reconfigurable pulleys and a belt vs a torque converter and traditional gears) and you have a very power-inefficient drivetrain.
Fine, the CVT is designed for great highway fuel mileage... but the minute you start dropping speed, your economy tanks, and the manual once again becomes the more efficient transmission. Look at the people who have CVT's who post their mileage in their sigs. Not many averaging in the 30's. Whereas MOST of the 6-speeds ARE in the 30's.
What we seem to have here is another case of EPA standard testing not reflecting realistic conditions. In the IDEAL conditions in the lab, the CVT edges out the manual... but they are also cruising at a constant speed, which doesn't happen in real life except travelling between cities... and even then not always. I find the newer EPA estimates to be more accurate, but still not accurate as they still give the CVT the edge. In the fuel economy study I did using NissanVersa.org members, the manual still beat out the CVT... and you can't accuse me of slanting the numbers either, because I rejected XterraVersa's data for being incorrectly formatted (thus eliminating a car that would have COMPLETELY whacked the curve in favor of the manual anyway)... the numbers I got were slanted in favor of the CVT, and it STILL lost.
WDRacing wrote:I'm just stimulating conversation.
As am I....
