MANUAL TRANS PROBLEM!! need help
blackonblack
i just did an auto to 5 speed swap and ive done three of these before. when the manual trans was out of the car its went through all the gears just fine. now when i have everything installed the car seems to be in gear when i have the shifter in the center (neutral)...it goes into the fifth gear and thats it but fifth gear wont engage when driving only when i stop...it wont go into gear no matter if the car is on or off except 5th...i cant seem to figure out the problem any ideas!!!??
Modified by blackonblack at 5:22 PM 9/26/2007
funigui
Car: I HAD a 1991 240sx coupe. woked NA motor. ran like 14.5 ish. blew it up @ 140 after an ECU reflash.
clutch fork stuck?
blackonblack
i can see the fork moving though and when i press the pedal it disengages
