manual trans in 99 G20t
geomecc
Car: 99 G20t
I got a 99 G20t with 5 speed manual. The transmission pops out of gear when i let off the gas , only in first gear.there is no problems in any other gear.I checked the motor mounts and they are good. What could be causing this?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Welcome to NICO!! I moved this to the Sentra forum, you will likely have a better response there!!!!!!
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
I say the culprit is the rear motor mount bracket on the cross member. Make sure you check that area again for a broken/lose bolt.
geomecc
Car: 99 G20t
i replaced the rear mount. problem still exists .what else would cause this?
geomecc
Car: 99 G20t
where can i find info for this transmission?
RED_DET
Vendor
2011 Infiniti G37x
Are you positive all the bolts are tight for the bracket that attaches to the motor/transmission.
