DeXteR »
https://forums.nicoclub.com/dexter-u32945.html
Mon Aug 20, 2007 3:56 am
yup, flip the switch on top of the pump motor. it's not too difficult to operate in this manor, but you're fighting a lot of dead weight. if you want to make your top "permanently" manual, you'd probably want to remove the pumps and lines and motor. don't break anything just in case you change your mind. with all the pumps and rams and lines out, it's not too bad opperating the top manually.
i have 2 verts, one has no rams or lines or anything and must be operated manually. before it was all twisted from the suicidal deer, it was relatively easy to put up and down. the other vert has an opperating auto top. when i was swapping the engines, i had to flip the pump switch and opperate it manually. it's not terribly difficult, but i wouldn't want to have to do it like that all the time.
