manual swap wiring problems
darko240sx
Car: 1989 240sx
i need help . My key is stuck in the ignition. My reverse lights don't work. My spedo does not work . What is the best way to wire the swap, using the manual harness or the auto or a combination. I need help i really jumbled the wiring. my car drives though!
mias13
Car: 1991 Nissan 240sx
well the key stuck in the ignition is just a relese that is hooked onto the automatic shift and once disconnected should not give you trouble. as for the speedo. when i did my swap the only thing that we hooked up was the speed sensor. the whole bottom transmission harness is pointless, bucnh of things you dont really need. just wire up the speed sensor and thats it
darko240sx
Car: 1989 240sx
thanks for the help every thing works now.
