manual swap???
Ricer240sx
Car: 89 240sx Coupe
ok im looking at getting a 240 with at bad engine cause i got a great idea (jun built engine:D ) but if i get one thats automatic and the engine i get comes with a transmission what else do i have to do to make it manual, if anything???:confused:
thanxchuck
Daunttless
I'm almost positive the JUN built engine doesn't come with a transmission, also, you'll need a SR bellhousing at the very least, I would suggest the SR transmission as well. Those aren't very easy to find alone. Also, you'll need all the clutch components, the cylinders and all the lines, the pedals, brackets, assembly, manual driveshaft, engine backing plate, new transmission crossmember and bolts, shifter, console pieces for the shifter with the bezel and shift boot and everything, thats all I can remember off hand, theres probably more that you need that I can't remember. Enjoy your day.
SpeedRacer1
Car: 1990 240SX, G35
Built JUN engines are extremely expensive, im not sure what the exact prices are but ive heard many rumors about them being well above 10000. Jun makes trannies if you want one of those. That'll probably run you another $8000 or so.
slw240sx
Car: 1990 Ca18det 240sx Hatch
goto 240sx.org , the install page has a step by step auto to manual swap, and the parts list needed to complete the swap is included !
s14=pimpin'
Car: 1995 Nissan 240SX SE S14
save yourself the headache and just buy a 5 speed 240. And please ricer guy, don't rice out the 240, especially if you are serious about a JUN engine.
peace
89sxRCR
Car: destroying self esteem
Or instead of doing just the manual swap go ahead with the sr Front clip, got every thing you need for the manual swap and its a lot cheaper then the JUN. A little research goes a long way :)
Ricer240sx
Car: 89 240sx Coupe
yeah the JUN idea was just bouncin around in my head (cause thers no brain so it gets good bounces) and im not sure about it
and don't worry im not gunna rice out the 240 im not that dumb!!! thats what the jettas for, exept it won't be complete rice, itll have a little pep in its step if u no what i mean:D :ylsuper :pface
