Manual swap driveshaft
llarashill
well when people sell their s13/14 driveshafts for manual swapsthey always say " abs" or "non-abs" if im doing a manual conversion for my KA vert. which one do i need an abs 5 speed DSor an non abs 5 speed DS
also this might be a rediculous Q but could a S14 DS work on a S13? or would it simply not work due to a length difference.
THANKS
94_240sx
Car: 94_240SX
As far as I know, you need s13 manual drive shaft for your vert. Length is different. Don't know about ABS. I hope it doesn't matter. I bought an s13 manual drive shaft, and I didn't check if it was from ABS or non-ABS car.
llarashill
thanksanyone else ???
biggie
For Vert you need S13 manual non-ABS driveshaft.
The ABS shaft is shorter for the ABS sensors/VLSD diff.
If you have a ABS VLSD pumpkin (from Hicas car or regular S13 ABS car) and input shaft you can use a ABS driveshaft.
Modified by biggie at 12:12 PM 9/27/2007
whoflungpoo
Car: 2006 Infinity G35 Sedan
2003 Evolution VIII
You CANNOT use a 14 driveshaft on a 13.
the carrier's bearings on the 13's are on the front, while the 14's are on the rear. not to mention the length difference.
Ask me how I know... go ahead, ask
afracer
Car: 92 240sx convertible, 72 Datsun, 69 Buick
Can't you just swap the front half of the driveshaft with your old driveshaft???? That's what I'd try first.
whoflungpoo
2003 Evolution VIII
afracer wrote:Can't you just swap the front half of the driveshaft with your old driveshaft???? That's what I'd try first.
I think you're correct on the S13's, as that's where the carrier bearing is attached, so I doubt there would be a difference between the ABS and non-abs driveshafts.
as for the definitive answer to the S13/14 driveshaft compatibility, here are 2 pics:
This is the S13 Driveshaft. Front of the car is on the right. Notice the carrier bearing location is on the FRONT half.
now, this is an S14 Driveshaft. Front is also on the right. Notice the carrier is on the REAR shaft.
I tried, god I tried, to get it to work, but there are no possible combination to make it.
Modified by whoflungpoo at 12:21 AM 9/30/2007
94_240sx
Car: 94_240SX
^^One of those should be s14, right?
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
correct.
you only need the front half of a manual s13 shaft, and you can use your rear half.
whoflungpoo
2003 Evolution VIII
94_240sx wrote:^^One of those should be s14, right?
sorry, yes. I fixed it.
I had just taken a break from pulling this damn SR and was in a hurry to get back out.
kitkat224
Car: 1996 Nissan Pathfinder SE (Sold), 1992 Nissan 240sx Convertible LE (Sold), 2004 Nissan 350z
Hurray!
ca18datsun510 wrote:correct.
Hurray!
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
or you can get a 1 piece alluminum driveshaft =D
