manual swap- car won't start??
maxima278
Car: 96 240SX SR20, 69 Ford Pickup, 99 Dodge Ram 1500, 1996 Nissan Maxima, 1997 Nissan Maxima project, 89 Coupe shell
my car is a 96 s14 auto, into which I have transplanted an entire 95 manual drivetrain; engine, transmission, wiring harness from right side of firewall (ecu) all the way to the ignition. I hear the fuel pump when I turn the ignition, but there is no turning over. Could it be that the auto car does not have the sensor to plug into the clutch pedal? (the one that engages when the clutch is mashed) how do I bypass this so that the engine will turn over? use laymans terms if you can so that it doesn't totally go over my headthanks
240KID~ZeRo.SiXtY
Car: 1989 Nissan 240sx
Did u convert a auto to a 5 speed?? If u did did u run all your lines for the clutch and u dont need that sensor because i know someone that dont have it either and it works just fine.
maxima278
My only theory to this is that I need to jump a wire together that will make the car think the clutch is mashed, but I wouldn't begin to know which one that would be
