Don't know if they ever made a manual rack or not the Z,but that info is wrong.a power rack that is not working is wayyyyyyy more effort than a manual rack. I have switch out a powered rack for a manual one in a f body mustang only big difference was in slow speed turns and such. Hope hat helps out.300ZXttZMAN wrote:You don't want to do that haha. Wait until you get your car back on the road then disable your powersteering try to drive then see what you think before you just decide to get rid of it all...
Ask me how I know? Well for some stupid reason right after I completed my build my Z's gear rack decided that it wanted to start leaking so instead of having to keep filling it up and leaking ATF all over my drive way and garage I decided to just take the belt off the pump until it was time to pull everything apart... Which we pulled the trans off yesterday I'm thinking we should be able to finish resealing oil pan and changing the gear rack by the end of next week.
buloushie wrote: Don't know if they ever made a manual rack or not the Z,but that info is wrong.a power rack that is not working is wayyyyyyy more effort than a manual rack. I have switch out a powered rack for a manual one in a f body mustang only big difference was in slow speed turns and such. Hope hat helps out.
NolimitZ32 wrote:1. buloushie is absolutely right, a manual rack will be much easier to work then a busted power rack, I used to have a civic with a manual rack, it wasnt easy to turn the wheel while sitting still but it was nothing compared to the muscle I had to use to crank the wheel on my old blazer when the PS packed up.
2. Dave Roys (can't remember his sn) has a manual rack that he had custom made I believe, track him down for more info.
Ahh interesting... Learn something new everyday, and come to think of it, it actually makes sense.addicted4life wrote:Reasoning behind the question is to clear up space. If I can remove the pump entirely then I have that many more options to run the piping. A manual rack is nothing like a dead ps pump in that they are geared lower inside so you can still turn it normally (save at low speeds, you feel the resistance from lack of motion).
This guy did it but I believe it is a custom fitted one.
http://m.6speedonline.com/forums/showth ... styleid=24
Found a set of TDM front mount manifolds for $1,350. Very nice product. Want to make sure I can do what I'm setting out to before I buy them.
bartZ32tt wrote:I just changed the steering rack bushings on my Z. It included a 3rd bushing for a 240sx that is unused for our Z's but the other bushing is the shared among the two chassis. Which leads me to believe that the 240sx steering rack is very similar, but inevitably different; not interchangeable.
Well I just checked the instructions sheet for you and ill be darned - the s13 and z32 chassis both share the same bushings. The s14 uses a different passenger bushing. Not sure how that translates to the overall steering rack itself but at least we now know that much!addicted4life wrote: What model year 240 if you don't mind me asking? If its very similar then it can be made to work with a little work.
^addicted4life wrote:A link to their website, lots of cars for you to drool over:P
http://jdm-ottawa.com/
evildky wrote:It's really not that big of a deal to modify the stock rack, I did my Z31. remove all the hydraulic lines from the rack, purge the fluid, loop the line and you're done. most people don't purge the system so when you are steering you are pushing all that fluid through those lines and that makes steering harder. granted manual steering is still gonna be harder than power most notably at parking speeds but unless you got girl arms it's not a big deal.
