ashoe wrote:You can just take off the power steering pump off, and connect the two sides of the steering rack together. Manual steering is not fun, I can't imagine why a manual rack would be better. There is lots of info on here about engine swaps and transmission swaps.
You just can't take off the PS pump. The pump runs in line water pump. So, if you take it off, no water pump.
You would need to use a power steering delete kit, or make one. I already done this, but my setup isn't in a 240sx. So I have no answers for the rack question. The kit moves the alternator, so it runs in line with the water pump, but then you would need the thermostat housing from a KA24"E" if you are doing this to a KA24DE, because the belt will rub on the housing if you don't.
