mrbean »
https://forums.nicoclub.com/mrbean-u11191.html
Tue Aug 31, 2004 9:41 pm
Hi,Finishing the install of a Clifford Matrix 3.5 to may manual '89 240sx hatch. I'm trying to rig up the neutral position sensor to the neutral safety switch that came with my alarm, so that the remote start won't activate unless the car's in neutral. According to the FSM, the neutral sensor has continuity only when the car is in the neutral position, meaning it's normally closed, but according to the ECU wiring diagram in the back, the neutral switch is normally open, meaning it DOESN'T have continuity in neutral. I've tried wiring it as both normally closed and open, and it seems the circuit is closed whether the car is in neutral or not.
Can anyone tell me how exactly the neutral sensor works?
Is it normally open or closed?
What causes it to sense whether the car is in gear or not? Does my foot have to be off the clutch while its in gear to trigger the sensor?
Any help would be greatly appreciated. Thanks!
