GraySilvia »
https://forums.nicoclub.com/graysilvia-u3605.html
Sat Mar 01, 2003 2:06 am
There are a few vacuum taps running off the top and body of the throttle body on a stock SR. The tops lines are vacuum lines, but the bottom ones are pressure only (boost). I think this is right, anyway. So what you want to do is run a hose from either side (just so long as it's getting boost) and connect that to your manual boost controller, then run a line out of the boost controller to the wastegate actuator itself. Then make sure you go easy of setting boost the first time so you can adjust it to where you want. You don't want to go out and boost 16 or 18 psi without warning. I hope this helps.
