NCGuy wrote:Hey all...I called around to local 4wheel shops and they are quoting me three hours for labor installing the manual hubs! I was just checking around as I am not sure how comfortable I am doing it myself. But I think they are trying to get over on me...so how difficult is this job really?
It was not difficult. Direct swap (for me).
3 hours seems a bit much, but perhaps the shop is thinking of another type of vehicle or part (cv joint/half shaft?).
***Caution*** Before you swap out your hubs, make sure that your wheels will fit over the new hub. Some wheels will not fit without being modified.***
Edit-adding: Perhaps the wheels not fitting is a reason for the high hourly quote, the shop would need to bore out your wheel to fit, then that is a reasonable quote.
