Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Mon Aug 25, 2014 3:28 am
Nissan calls the auto computer the ATCU. TCU is the timing control unit present on all cars regardless of transmission type. Your big concern is convincing the car that the clutch interlock relay is working. It's a relay on manual cars that closes a loop to activate the starter only when the clutch is depressed (Americans are stupid and can't figure out that clutches should be disengaged when starting vehicles). So basically, if you go to the two plugs near your battery tray that look like they should plug into something by the fender, find the plug that has the black/white and black/yellow wires and jump them. Now when you turn the key to start, you won't have an annoying relay inline keeping you from starting the car.
