Manual Engine in my Auto 200sx?!?!?! HELP PLEASE!!!!
pimms200sx
Car: 1991 Nissan 200sx Turbo
hi guys, i've had a lil' problem with my car recently. its a 1991 auto 200sx turbo.
i blew a hole in the side of my block (see below), so i bought a new engine off of ebay.
when it arrived it had a clutch still on it. so i removed it and the flywheel in order to fit the torque converter. BUT, when i went to fit the auto flywheel to the end of the crank it was different. the small hub thing that the flywheel bolts into should have a bit sticking out a little further so the torque converter fits, but it doesnt on the manual engine. so i want to take it off of the old crank but i dont know how it comes off.
PLEASE HELP!!!!
irocknrol2
Car: 1991 240sx Hatch/1993 240sx Coupe
Thats the pilot bushing. It is different for a manual trans. Its smaller. You have to have a puller to remove it. You can rent one from a local auto store usually. When you go to put the auto one in you can find a socket of approximately the same size as the bushing to put it in place.
