azncorruptedo17 »
https://forums.nicoclub.com/azncorruptedo17-u17403.html
Mon Jan 03, 2005 6:29 am
The difference with Automatic ECU in a 5speed Manual is that the fuel cut off is higher, rev limit is higher and i believe it will also lower your mpg since it will dump more fuel and put out more power, nothing drastic though i just wanted to throw that out for you.
Also, with an AT ecu in a MT, you need to adjust the Idle since it will probably be funky at the start, so adjusting the idle will fix that easily. Other than that an AT ecu in an MT is a good easy and cheap upgrade =]
