Manual drivers' question
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Reidso
Car: 2009 Versa
New to the forum and I'm driving a 2009 Versa with a manual 6 speed. My question concerns the transmission. When I depress the clutch to shift the revs stay high, only dropping slightly by the time I get it into the next gear. Is this normal for this car? Feels odd to me. My other manuals are not like this; revs falling while you shift, then increasing as you put your foot into it. Thanks for any advice.
TheSilverVersa07
Car: 2007 Nissan Versa, 1991 Camaro Z28,
2008 Can-Am Spyder RS
Reidso wrote:New to the forum and I'm driving a 2009 Versa with a manual 6 speed. My question concerns the transmission. When I depress the clutch to shift the revs stay high, only dropping slightly by the time I get it into the next gear. Is this normal for this car? Feels odd to me. My other manuals are not like this; revs falling while you shift, then increasing as you put your foot into it. Thanks for any advice.
Now im only thinking of the top of my head but, i think this car has a short gear ratio and personally the car would of been better a 5 spd but i cant complain for the 6. its just that the top speed on these things are 120? and to divide that into six gears is pushin it if you ask me.
Reidso
Car: 2009 Versa
I agree TSV07. You sure do end up stirring that gearbox a lot. Do you find the revs stay high between shifts, or is that just me? In my other manual car (73 TR6) the revs drop off between shifts. I find it strange that (for example) when I shift into 2nd, or whatever, the revs are where I left them after shifting from 1st-maybe 3000 rpm? Do you find the same? I'm just trying to determine if this is normal for a Versa. Thanks.
led hed
Car: 2009 Nissan Versa SL HB 6spd
yep, mine does the same. at least this way the synchros won't wear out too soon.
08versailles
Car: 08 Versa SL 6sp
09 Altima 2.5S cvt REAR ENDED and WRITTEN OFF
13 Charger SXT 8sp auto
Reidso wrote: When I depress the clutch to shift the revs stay high, only dropping slightly by the time I get it into the next gear. Is this normal for this car?
I drove a newer Focus that did the same thing, and my V does too, but not as pronounced as the Focus.
My mechanic says they do that on purpose to keep emissions down.
I assume this burns fuel not instantaneously stopped when gas pedal is released.
I also assume this could be done intentionally with or without an actual throttle cable.
So shift quicker! :biggrin: I mean...more efficiently!
Return to “Versa Technical Discussions”
